Connector at rear of Philco 41-280 and 41-250 chassis
I have a 41-280 and a 41-250. Both have a 3 pin socket near the center of the rear of the chassis. I can't tell from the schematic what that is to be used for. I have seen a couple of pictures on ebay that show what looks like a coil (in a can) plugged into that socket.
Anyone have any idea what that was used for?
John Honeycutt
Connector at rear of Philco 41-280 and 41-250 chassis - by Raleigh - 05-06-2007, 11:26 AM
[No subject] - by Terry Judkins - 05-07-2007, 08:50 PM
[No subject] - by Raleigh - 05-08-2007, 09:57 AM
