1000 V Capacitors in 41-250
I'm ordering parts to recap a model 41-250. Three of the .003 microfarad caps are labeled 1000 VDC. These caps seem to be bypass caps in the plate circuits of the 1st audio tube and the push-pull output tubes.
Do these really need to be 1000 volt caps? I'm just a beginner at this, but I've not run across this before.
Edited to add: I did a quick search and found this topic has been asked and answered before. The caps I have are definately Philco -- probably originals (P/N 30-4469 S.)
I guess this means I'll order the 1000 V replacements....
John Honeycutt
1000 V Capacitors in 41-250 - by Raleigh - 05-06-2007, 09:56 PM
[No subject] - by Ron Ramirez - 05-13-2007, 02:13 PM
Re: 1000 V Capacitors in 41-250 - by OldJack1969 - 12-08-2011, 05:59 PM
Re: 1000 V Capacitors in 41-250 - by exray - 12-08-2011, 08:15 PM
Re: 1000 V Capacitors in 41-250 - by Ron Ramirez - 12-09-2011, 08:41 PM
Re: 1000 V Capacitors in 41-250 - by codefox1 - 12-10-2011, 12:30 AM
Re: 1000 V Capacitors in 41-250 - by Texasrocker - 12-10-2011, 01:26 AM
Re: 1000 V Capacitors in 41-250 - by Marsupial - 12-10-2011, 05:24 PM
Re: 1000 V Capacitors in 41-250 - by exray - 12-10-2011, 06:18 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5732 online users. [Complete List]
» 1 Member(s) | 5731 Guest(s)
