Model 41-280 "slide Rule" dial
Hi Bill,
I'm going to be a little busier than usual this week, so if someone else doesn't get this info for you, I can do so later this week. I could pull the sheet out of the one I'm working on and scan it for you at that time.
Bill
Sent from my Pentium II on the AT&T Dial Network
Model 41-280 "slide Rule" dial - by bill T - 11-07-2005, 07:50 AM
[No subject] - by Bill Hutchinson - 11-07-2005, 11:31 AM
[No subject] - by bill T - 11-08-2005, 07:50 AM
[No subject] - by bill T - 11-19-2005, 11:43 AM
[No subject] - by Bill Hutchinson - 11-19-2005, 05:35 PM
[No subject] - by bill T - 11-22-2005, 02:52 PM
[No subject] - by Bill Hutchinson - 11-22-2005, 07:58 PM
[No subject] - by bill T - 11-23-2005, 01:07 AM
[No subject] - by Bill Hutchinson - 12-01-2005, 02:50 PM
[No subject] - by bill T - 12-03-2005, 08:01 AM
[No subject] - by Bill Hutchinson - 01-04-2006, 05:52 PM
Philco 91 Tuning Condenser
