  • 1 Vote(s) - 4 Average
Ron's Cabinet Work for the 2012 Season
#49
Very niceIcon_thumbupIcon_thumbupIcon_thumbup
M R Radios   C M Tubes
RE: Ron's Cabinet Work for the 2012 Season - by Steve Davis - 08-19-2012, 09:25 PM
Users browsing this thread: 13 Guest(s)
With these values I think you are OK; the Cmax for this tube is 40uF. Your Vbb could rise a bit, but probably not too m...morzh — 04:53 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 1908 online users. [Complete List]
» 3 Member(s) | 1905 Guest(s)
