A 3 hour chore
Great job DK but dang, what a mess of tar! From the look of the pieces I would guess you had to chip the thing out. Well done. Mine as well but also, no change in how my 111 works ( poorly) but at least in didn't get worse. On to the rest of the chassis.
Good luck. Jerry
A 3 hour chore - by DKinYORKpa - 08-18-2012, 04:19 PM
RE: A 3 hour chore - by codefox1 - 08-18-2012, 04:36 PM
RE: A 3 hour chore - by Phlogiston - 08-18-2012, 05:16 PM
RE: A 3 hour chore - by TA Forbes - 08-19-2012, 04:44 AM
RE: A 3 hour chore - by DeckApe - 08-19-2012, 08:17 AM
RE: A 3 hour chore - by TA Forbes - 08-19-2012, 12:10 PM
RE: A 3 hour chore - by DeckApe - 08-19-2012, 11:37 PM
RE: A 3 hour chore - by jerryhawthorne - 08-20-2012, 01:27 AM
RE: A 3 hour chore - by PhilcoMike - 08-20-2012, 11:16 AM
RE: A 3 hour chore - by Phlogiston - 08-20-2012, 12:57 PM
RE: A 3 hour chore - by TA Forbes - 08-21-2012, 12:00 PM
RE: A 3 hour chore - by codefox1 - 08-21-2012, 01:00 PM
The speaker table error?
Philco 70 antenna lead
