Filter choke in Philco 201
Dang Mark, you already got into it? Hide it soon, the wife may get home. I figured it would take you a year to get to it at a minimum. Good luck on it, nice radio.
Jerry
Filter choke in Philco 201 - by retiredinprescott - 08-19-2012, 09:24 PM
RE: Filter choke in Philco 201 - by morzh - 08-19-2012, 11:19 PM
RE: Filter choke in Philco 201 - by jerryhawthorne - 08-20-2012, 01:30 AM
RE: Filter choke in Philco 201 - by TA Forbes - 08-21-2012, 12:03 PM
RE: Filter choke in Philco 201 - by codefox1 - 08-21-2012, 12:56 PM
The speaker table error?
Philco 70 antenna lead
