Please Help ID this Philco
It's a 1938 Model 38-610.
I believe Philco "re-issued" the later production runs of the 1937 version again in 1938. Virtually same chassis. May have been "leftover" later Code chassis' used for the start of the 1938 production runs for Model Year 1938.
The "610's" were a very popular set.
Ron may be able to add.
Chuck
Please Help ID this Philco - by GaryM - 08-19-2012, 08:24 PM
RE: Please Help ID this Philco - by Jayce - 08-19-2012, 10:27 PM
RE: Please Help ID this Philco - by DeckApe - 08-19-2012, 11:54 PM
RE: Please Help ID this Philco - by Chuck Schwark - 08-20-2012, 09:37 AM
RE: Please Help ID this Philco - by Ron Ramirez - 08-20-2012, 04:13 PM
RE: Please Help ID this Philco - by GaryM - 08-20-2012, 10:31 PM
RE: Please Help ID this Philco - by Arran - 08-21-2012, 12:16 AM
RE: Please Help ID this Philco - by TA Forbes - 08-21-2012, 11:57 AM
RE: Please Help ID this Philco - by codefox1 - 08-21-2012, 12:42 PM
RE: Please Help ID this Philco - by Ron Ramirez - 08-21-2012, 03:54 PM
RE: Please Help ID this Philco - by Ron Ramirez - 08-24-2012, 03:50 PM
RE: Please Help ID this Philco - by Chuck Schwark - 08-24-2012, 04:59 PM
Philco 91 Tuning Condenser
There are currently 5715 online users. [Complete List]
» 1 Member(s) | 5714 Guest(s)
