Presenting the Stromberg-Carlson 12A!
Well, even if I do trade it, it will only be a short trip away at my friend's place. He loves six legged radios and he was actually offered this radio before me, but didn't have the cash at the time. So, he sent it my way instead. This isn't the first radio I've had that has refused to work here. I've still got yet another radio that acts for all the world like it has bad IFs when you use it on this property. Take it a short distance away to another area and it works like a champ. Sometimes I wonder about our power lines out this way, they are in bad shape.
Presenting the Stromberg-Carlson 12A! - by Jayce - 10-31-2011, 07:38 PM
RE: Presenting the Stromberg-Carlson 12A! - by Jayce - 08-20-2012, 04:56 PM
Philco 91 Tuning Condenser
There are currently 8387 online users. [Complete List]
» 2 Member(s) | 8385 Guest(s)
