Tube Testing - 46-200
Ron, Thanks for the link. I will definitely try this. I am hoping that once I replace the improper tubes and "fix" the antenna problem, that the radio should be much closer to being functional again.
In any case, since I can at least tune in a station, I still have some hope that I can get it working again.
Tube Testing - 46-200 - by winkydink - 08-19-2012, 09:45 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-19-2012, 10:27 AM
RE: Tube Testing - 46-200 - by winkydink - 08-19-2012, 11:29 AM
RE: Tube Testing - 46-200 - by codefox1 - 08-19-2012, 01:01 PM
RE: Tube Testing - 46-200 - by Paul Philco322 - 08-19-2012, 08:17 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 08:37 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-20-2012, 08:45 AM
RE: Tube Testing - 46-200 - by codefox1 - 08-20-2012, 01:17 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 01:26 PM
RE: Tube Testing - 46-200 - by codefox1 - 08-20-2012, 01:53 PM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-20-2012, 04:29 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 09:47 PM
RE: Tube Testing - 46-200 - by winkydink - 09-04-2012, 08:29 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 09-04-2012, 08:44 AM
RE: Tube Testing - 46-200 - by winkydink - 09-04-2012, 08:58 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 09-04-2012, 09:22 AM
RE: Tube Testing - 46-200 - by TimC - 09-07-2012, 10:26 PM
The speaker table error?
Philco 70 antenna lead
