Mystery Brunswick Console
I would keep the Stromberg and try getting it to play better, it's a far better radio then a Radiola 60 Brunswick clone would be, if only for the few years extra technological refinement. In answer to your question yes Brunswick made lots of sets without a phonograph, they made table model versions as well with a seperate speaker. RCA did not make these sets, Brunswick made these under license, RCA didn't make anything until they took over Victor. The power supply chassis does just that I believe, in my Westinghouse 89, which is similar to a Radiola 63, the only tube in that chassis is the type 80, the power output amp is on one end of the tuner chassis.
Mystery Brunswick Console - by Jayce - 08-20-2012, 08:08 PM
RE: Mystery Brunswick Console - by Carl Travis - 08-21-2012, 12:03 AM
RE: Mystery Brunswick Console - by Arran - 08-21-2012, 01:08 AM
RE: Mystery Brunswick Console - by Doug Houston - 08-21-2012, 05:36 PM
RE: Mystery Brunswick Console - by Jayce - 08-21-2012, 06:47 PM
RE: Mystery Brunswick Console - by Arran - 08-21-2012, 08:03 PM
RE: Mystery Brunswick Console - by Doug Houston - 08-23-2012, 01:31 AM
Philco 91 Tuning Condenser
There are currently 10062 online users. [Complete List]
» 1 Member(s) | 10061 Guest(s)
