Mystery Brunswick Console
Both my friend and I are hoping this radio performs well. I was baffled by the lack of a Panatrope, thinking it got removed. But, the top doesn't open and show no signs of ever having the Panatrope there. I was just checking before I made any decisions. I have seen the version of this radio with the Panatrope pictured online and I think cabinet was just a hair taller than this one to fit the phonograph in.
I used to have a Radiola 60 and have a Radiola 66. I've had very good luck with the Superherterodyne era of Radiolas. Always good performers that suck in stations better than some later radios in my opinion.
Mystery Brunswick Console - by Jayce - 08-20-2012, 08:08 PM
RE: Mystery Brunswick Console - by Carl Travis - 08-21-2012, 12:03 AM
RE: Mystery Brunswick Console - by Arran - 08-21-2012, 01:08 AM
RE: Mystery Brunswick Console - by Doug Houston - 08-21-2012, 05:36 PM
RE: Mystery Brunswick Console - by Jayce - 08-21-2012, 06:47 PM
RE: Mystery Brunswick Console - by Arran - 08-21-2012, 08:03 PM
RE: Mystery Brunswick Console - by Doug Houston - 08-23-2012, 01:31 AM
Philco 91 Tuning Condenser
There are currently 8816 online users. [Complete List]
» 3 Member(s) | 8813 Guest(s)
