battery pack for Philco 39-85 121
I made a cover for the A battery, kind of an odd shaped affair. I can send the patterns if you'd like.
Bill
battery pack for Philco 39-85 121 - by Tank - 07-27-2012, 04:34 PM
RE: battery pack for Philco 39-85 121 - by Tank - 08-01-2012, 03:47 PM
RE: battery pack for Philco 39-85 121 - by Tank - 08-02-2012, 12:15 AM
RE: battery pack for Philco 39-85 121 - by batterymaker - 08-22-2012, 10:59 PM
The speaker table error?
Philco 70 antenna lead
