Philco Type 611 in New Zealand
Hi
Yes, please do take some pictures. If for no other reason, I would like to add photos of your set to Philcoradio.com with your permission.
Once we see photos, there may be a chance we might be able to help you positively identify the set, and to dispose of the chassis (hopefully to another collector).
Philco Type 611 in New Zealand - by davida - 08-24-2012, 06:01 AM
RE: Philco Type 611 in New Zealand - by Ron Ramirez - 08-24-2012, 03:43 PM
RE: Philco Type 611 in New Zealand - by davida - 08-25-2012, 05:45 AM
RE: Philco Type 611 in New Zealand - by davida - 08-25-2012, 07:46 AM
RE: Philco Type 611 in New Zealand - by davida - 08-25-2012, 08:00 AM
RE: Philco Type 611 in New Zealand - by davida - 08-25-2012, 11:53 PM
RE: Philco Type 611 in New Zealand - by davida - 08-26-2012, 03:13 AM
Philco 91 Tuning Condenser
