Zenith 723R on the fritz
Hi Gang:
I have a neat little Zenith 723R, am/fm. Always a good sounding set, but is developing tons of static on AM picks up only 1-2 stations on AM where as before it was quite sensitive.
It has had capacitors switched out, resistors checked. Is there a tube in these little guys that has more impact on AM that could be a likely culprit? Still plays very well on FM. Any suggestions are appreciated.
Zenith 723R on the fritz - by Paul Philco322 - 08-24-2012, 08:28 PM
RE: Zenith 723R on the fritz - by Ron Ramirez - 08-24-2012, 09:34 PM
RE: Zenith 723R on the fritz - by codefox1 - 08-24-2012, 10:28 PM
RE: Zenith 723R on the fritz - by Paul Philco322 - 08-24-2012, 10:42 PM
RE: Zenith 723R on the fritz - by Arran - 08-25-2012, 12:42 AM
RE: Zenith 723R on the fritz - by Paul Philco322 - 09-06-2012, 08:45 PM
Philco 91 Tuning Condenser
