Zenith 723R on the fritz
It sounds like your set may be suffering from silver mica disease. What you describe (lots of static on AM) is the classic symptom.
What this means is, the mica capacitors in the AM IF transformers have gone bad, and will require replacement.
This, from what I have read (I've never done this repair), is not easy, but not terribly difficult if you are very careful.
Zenith 723R on the fritz - by Paul Philco322 - 08-24-2012, 08:28 PM
RE: Zenith 723R on the fritz - by Ron Ramirez - 08-24-2012, 09:34 PM
RE: Zenith 723R on the fritz - by codefox1 - 08-24-2012, 10:28 PM
RE: Zenith 723R on the fritz - by Paul Philco322 - 08-24-2012, 10:42 PM
RE: Zenith 723R on the fritz - by Arran - 08-25-2012, 12:42 AM
RE: Zenith 723R on the fritz - by Paul Philco322 - 09-06-2012, 08:45 PM
Philco 91 Tuning Condenser
There are currently 6600 online users. [Complete List]
» 2 Member(s) | 6598 Guest(s)
