philco model 16
someone also connected a paper capacitor mallory ( i can't tell value until i remove it ) from screen grid of 42 tube closest to edge to center terminal of capacitor 86 a resistor no. 85 10,000 ohms also is connected at this spot it starts at the screen grid of the other 42 tube
philco model 16 - by ckc - 04-29-2007, 08:13 AM
[No subject] - by Chuck Schwark - 04-29-2007, 11:26 AM
[No subject] - by ckc - 04-29-2007, 01:03 PM
[No subject] - by Chuck Schwark - 04-29-2007, 02:47 PM
[No subject] - by ckc - 04-29-2007, 04:27 PM
[No subject] - by ckc - 04-29-2007, 05:14 PM
[No subject] - by Sean - 04-30-2007, 08:09 AM
[No subject] - by Sean - 04-30-2007, 09:14 PM
[No subject] - by ckc - 05-02-2007, 07:34 PM
[No subject] - by Sean - 05-03-2007, 08:21 AM
[No subject] - by ckc - 05-03-2007, 03:49 PM
[No subject] - by Sean - 05-03-2007, 05:10 PM
[No subject] - by ckc - 05-03-2007, 06:45 PM
[No subject] - by Sean - 05-04-2007, 08:43 AM
[No subject] - by ckc - 05-09-2007, 05:08 PM
[No subject] - by Sean - 05-09-2007, 05:14 PM
[No subject] - by ckc - 05-09-2007, 05:42 PM
[No subject] - by Sean - 05-10-2007, 08:09 AM
[No subject] - by ckc - 05-11-2007, 10:32 PM
[No subject] - by Sean - 05-12-2007, 08:16 PM
[No subject] - by ckc - 05-16-2007, 11:55 AM
[No subject] - by ckc - 05-18-2007, 05:20 PM
[No subject] - by ckc - 05-18-2007, 05:41 PM
[No subject] - by Sean - 05-19-2007, 08:26 PM
[No subject] - by ckc - 05-28-2007, 02:52 PM
[No subject] - by Sean - 05-28-2007, 05:37 PM
[No subject] - by ckc - 06-01-2007, 11:40 PM
There are currently 10420 online users. [Complete List]
» 2 Member(s) | 10418 Guest(s)
