Did the 38-3 have an antenna?
Hi Jon
This set was designed for an external antenna; specifically, the Philco High Efficiency Aerial. Any longwire antenna may also be used by connecting it to the terminal in back marked RED. With a simple longwire, there should be a jumper connected between the BLK and GND terminals.
Did the 38-3 have an antenna? - by Jon Scaptura - 05-20-2007, 06:58 PM
[No subject] - by Ron Ramirez - 05-20-2007, 11:08 PM
Re: Did the 38-3 have an antenna? - by n9vu - 05-23-2007, 06:32 AM
[No subject] - by 49Stude63 - 09-28-2007, 11:52 PM
[No subject] - by Jon Scaptura - 09-29-2007, 12:08 PM
[No subject] - by Texasrocker - 09-29-2007, 10:18 PM
[No subject] - by davemc - 10-19-2007, 03:23 PM
[No subject] - by Jon Scaptura - 10-19-2007, 06:35 PM
