A Zenith 10S669
I have one of those too.
All re-capped and sounds awesome.
[Image: http://i1161.photobucket.com/albums/q509...G_1387.jpg]
A Zenith 10S669 - by 37silverstreak - 06-10-2012, 03:19 PM
RE: A Zenith 10S669 - by rocketeer - 06-13-2012, 11:05 AM
RE: A Zenith 10S669 - by Jayce - 06-13-2012, 11:09 AM
RE: A Zenith 10S669 - by Arran - 06-14-2012, 01:19 AM
RE: A Zenith 10S669 - by murf - 09-03-2012, 04:53 PM
RE: A Zenith 10S669 - by rocketeer - 09-03-2012, 06:17 PM
RE: A Zenith 10S669 - by murf - 09-03-2012, 07:33 PM
Philco 91 Tuning Condenser
There are currently 8818 online users. [Complete List]
» 3 Member(s) | 8815 Guest(s)
