rca model 816k
I'd replace the "cough drops" too, you can look them up in the parts list, check the antenna coil as well. Alignment will take a while.
Schematic and alignment instructions here:
http://www.nostalgiaair.org/PagesByModel...015155.pdf
rca model 816k - by murf - 11-29-2011, 05:47 PM
RE: rca model 816k - by murf - 09-03-2012, 05:14 PM
RE: rca model 816k - by codefox1 - 09-03-2012, 06:33 PM
RE: rca model 816k - by Arran - 09-03-2012, 07:02 PM
Re: rca model 816k - by TA Forbes - 11-29-2011, 08:40 PM
Re: rca model 816k - by Doug Houston - 12-06-2011, 01:39 AM
Re: rca model 816k - by murf - 12-06-2011, 08:02 AM
Re: rca model 816k - by TA Forbes - 12-06-2011, 09:50 PM
Re: rca model 816k - by Ron Ramirez - 12-10-2011, 08:03 PM
Re: rca model 816k - by TA Forbes - 12-10-2011, 11:21 PM
Re: rca model 816k - by Glenn Roberts - 12-11-2011, 07:35 AM
Re: rca model 816k - by mukerjea - 12-16-2011, 09:59 PM
Re: rca model 816k - by Glenn Roberts - 12-17-2011, 08:44 AM
Re: rca model 816k - by mukerjea - 12-17-2011, 10:08 AM
Re: rca model 816k - by John R - 12-17-2011, 09:12 PM
Re: rca model 816k - by TA Forbes - 12-18-2011, 01:51 PM
Re: rca model 816k - by mukerjea - 12-18-2011, 03:28 PM
Re: rca model 816k - by murf - 12-20-2011, 11:42 PM
Re: rca model 816k - by murf - 12-29-2011, 01:53 PM
Re: rca model 816k - by codefox1 - 12-29-2011, 02:21 PM
Re: rca model 816k - by murf - 12-29-2011, 02:44 PM
Re: rca model 816k - by TA Forbes - 12-29-2011, 03:49 PM
Re: rca model 816k - by murf - 12-29-2011, 10:31 PM
Re: rca model 816k - by codefox1 - 12-30-2011, 01:00 PM
Re: rca model 816k - by TA Forbes - 12-30-2011, 09:55 PM
Re: rca model 816k - by murf - 12-30-2011, 11:45 PM
Re: rca model 816k - by murf - 01-04-2012, 11:50 PM
Re: rca model 816k - by Dave - 01-05-2012, 09:50 AM
Philco 91 Tuning Condenser
There are currently 8877 online users. [Complete List]
» 2 Member(s) | 8875 Guest(s)
