Tube Testing - 46-200
Ron,
Would this be good wire to use for the antenna construction
http://www.amazon.com/Magnet-Enameled-Co...e+enameled
If not, can someone post a link to the proper type of wire to use.
Thanks !
Tube Testing - 46-200 - by winkydink - 08-19-2012, 09:45 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-19-2012, 10:27 AM
RE: Tube Testing - 46-200 - by winkydink - 08-19-2012, 11:29 AM
RE: Tube Testing - 46-200 - by codefox1 - 08-19-2012, 01:01 PM
RE: Tube Testing - 46-200 - by Paul Philco322 - 08-19-2012, 08:17 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 08:37 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-20-2012, 08:45 AM
RE: Tube Testing - 46-200 - by codefox1 - 08-20-2012, 01:17 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 01:26 PM
RE: Tube Testing - 46-200 - by codefox1 - 08-20-2012, 01:53 PM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-20-2012, 04:29 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 09:47 PM
RE: Tube Testing - 46-200 - by winkydink - 09-04-2012, 08:29 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 09-04-2012, 08:44 AM
RE: Tube Testing - 46-200 - by winkydink - 09-04-2012, 08:58 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 09-04-2012, 09:22 AM
RE: Tube Testing - 46-200 - by TimC - 09-07-2012, 10:26 PM
The speaker table error?
Philco 70 antenna lead
