Tube Testing - 46-200
Thanks Ron,
Really silly question, but still new to all of this. What gage/type of wire should I purchase to replace the wiring found in the chassie (sp) for the 1939-42 Philco radios. Links to items would be most appreciated.
Thanks.
-Jim
Tube Testing - 46-200 - by winkydink - 08-19-2012, 09:45 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-19-2012, 10:27 AM
RE: Tube Testing - 46-200 - by winkydink - 08-19-2012, 11:29 AM
RE: Tube Testing - 46-200 - by codefox1 - 08-19-2012, 01:01 PM
RE: Tube Testing - 46-200 - by Paul Philco322 - 08-19-2012, 08:17 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 08:37 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-20-2012, 08:45 AM
RE: Tube Testing - 46-200 - by codefox1 - 08-20-2012, 01:17 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 01:26 PM
RE: Tube Testing - 46-200 - by codefox1 - 08-20-2012, 01:53 PM
RE: Tube Testing - 46-200 - by Ron Ramirez - 08-20-2012, 04:29 PM
RE: Tube Testing - 46-200 - by winkydink - 08-20-2012, 09:47 PM
RE: Tube Testing - 46-200 - by winkydink - 09-04-2012, 08:29 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 09-04-2012, 08:44 AM
RE: Tube Testing - 46-200 - by winkydink - 09-04-2012, 08:58 AM
RE: Tube Testing - 46-200 - by Ron Ramirez - 09-04-2012, 09:22 AM
RE: Tube Testing - 46-200 - by TimC - 09-07-2012, 10:26 PM
The speaker table error?
Philco 70 antenna lead
