Philco 46E - Testing Tubes
Have you looked at this schematic?
http://www.philcoradio.com/tech/images/46.jpg
This is taken from the original Philco Service Bulletin for Models 46 and 46-E, and is indeed different from what is printed in Rider's.
Bulletin 53 (the original Bulletin for Models 46 and 46-E) specifies a Type 2 ballast for Model 46 and a Type 3 ballast for Model 46-E. The two are otherwise the same according to this Bulletin.
While it is possible that yours could be a factory variant, bear in mind that both domestic and export versions of the 46 were made in Philadelphia. It would be a few years before Philco built its Perivale, Greenford, Middlesex (UK) factory for the British/European market.
I, for one, would be most interested in seeing your homemade schematic when you complete it, to compare it to the Bulletin 53 schematic.
Philco 46E - Testing Tubes - by davemc - 05-18-2007, 11:07 AM
[No subject] - by Fred R - 05-21-2007, 12:44 PM
[No subject] - by davemc - 05-22-2007, 08:57 AM
[No subject] - by Fred R - 05-22-2007, 09:41 AM
[No subject] - by davemc - 05-22-2007, 11:58 AM
[No subject] - by Ron Ramirez - 05-26-2007, 11:47 AM
[No subject] - by davemc - 05-26-2007, 12:52 PM
There are currently 6025 online users. [Complete List]
» 2 Member(s) | 6023 Guest(s)
