1941 Philco BOL Changer
I have this changer that I am restoring from a 41-608. It is working but I cannot get the auto reject at the end of playing a record adjusted properly. I can get it to either trip early or not at all. If anyone has worked on one of these can you give me some tips? I have the Philco service manual covering this changer but it doesn't give me any help on this problem.
Sean
WØKPX
1941 Philco BOL Changer - by Sean - 05-26-2007, 11:55 AM
There are currently 3886 online users. [Complete List]
» 4 Member(s) | 3882 Guest(s)
AvatarAvatarAvatarAvatar
