started (at last) to refinish my 47-1230
Mars, banding is about twice as thick as normal veneer, this is what you need http://www.constantines.com/search.aspx?...tegory=166
M R Radios   C M Tubes
RE: started (at last) to refinish my 47-1230 - by Steve Davis - 09-05-2012, 12:22 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 1975 online users. [Complete List]
» 3 Member(s) | 1972 Guest(s)
