  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
I thought about drilling it out the way you mentioned but since it is only noticed when viewed from the underside of the chassis I wasn't as concerned. And in all honesty, I just wasn't motivated enough so I just tossed out the innards.
I'll try your tip on the aluminum electrolytic on my next project.
Thanks!!!
- Geoff
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by Geoff - 09-05-2012, 06:41 PM
There are currently 3487 online users. [Complete List]
» 1 Member(s) | 3486 Guest(s)
