Philco 38-3 console
It's a decent nine-tube set. Not as good as your 116, but still pretty good.
If it's worth it to you, grab it!
Philco 38-3 console - by PhilcoJohn - 09-06-2012, 07:12 PM
RE: Philco 38-3 console - by TA Forbes - 09-06-2012, 10:45 PM
Philco 91 Tuning Condenser
There are currently 5400 online users. [Complete List]
» 1 Member(s) | 5399 Guest(s)
