started (at last) to refinish my 47-1230
Before I go to the store...
to go over the toner, what kind of lacquer should I get?
Also, I have read online of aerosol toners and lacquers... are they any good?
-Mars
RE: started (at last) to refinish my 47-1230 - by Marsupial - 09-07-2012, 09:28 AM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2502 online users. [Complete List]
» 4 Member(s) | 2498 Guest(s)
AvatarAvatarAvatarAvatar
