Philco Model Mystery
Looks like a model 71 to me. It should have seven tubes.
Philco Model Mystery - by mgambuzza - 09-07-2012, 11:37 PM
RE: Philco Model Mystery - by TA Forbes - 09-08-2012, 12:58 AM
RE: Philco Model Mystery - by mgambuzza - 09-08-2012, 01:00 AM
RE: Philco Model Mystery - by TA Forbes - 09-08-2012, 01:04 AM
RE: Philco Model Mystery - by Chuck Schwark - 09-10-2012, 10:13 AM
Philco 91 Tuning Condenser
There are currently 3761 online users. [Complete List]
» 1 Member(s) | 3760 Guest(s)
