New member
Hello, and welcome! This is a great place not only for the Philco (and other brands) knowledge but also for the great people.
The 37-660 is a great looking set. Not too tough to work on until you re-cap the RF deck.
New member - by mgambuzza - 09-07-2012, 11:16 PM
RE: New member - by TA Forbes - 09-08-2012, 01:01 AM
Philco 91 Tuning Condenser
