started (at last) to refinish my 47-1230
I went back to the store and changed the satin lacquer for glossy lacquer.
However, they don't have walnut veneer. They have maple, oak, pine and birch. The cut isn't mentionned. Would it be OK to use birchwood on the shoulder tops?
-Mars
RE: started (at last) to refinish my 47-1230 - by Marsupial - 09-08-2012, 02:22 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2575 online users. [Complete List]
» 4 Member(s) | 2571 Guest(s)
AvatarAvatarAvatarAvatar
