New Flea Market found and Philcos!
Jayce
Great finds, congrats! Icon_thumbup
The cabinet design of your 18 (official model: 18LS) was also used to house models 14, 16, 17, and even the 19 at one point.
http://www.philcoradio.com/gallery/1933c.htm#j
I could use a good, large photo of your 18LS in place of the poor illustration in the Gallery link above (hint, hint). Icon_wink
New Flea Market found and Philcos! - by Jayce - 09-08-2012, 08:17 PM
RE: New Flea Market found and Philcos! - by Ron Ramirez - 09-08-2012, 08:36 PM
RE: New Flea Market found and Philcos! - by Jayce - 09-08-2012, 09:06 PM
RE: New Flea Market found and Philcos! - by Jayce - 09-10-2012, 07:30 PM
RE: New Flea Market found and Philcos! - by gregb - 01-24-2014, 02:08 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-24-2014, 03:40 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-26-2014, 08:01 PM
RE: New Flea Market found and Philcos! - by Arran - 01-27-2014, 10:28 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-28-2014, 12:23 AM
RE: New Flea Market found and Philcos! - by Arran - 01-28-2014, 04:26 AM
RE: New Flea Market found and Philcos! - by Jamie - 01-28-2014, 05:07 PM
Philco 91 Tuning Condenser
There are currently 10034 online users. [Complete List]
» 2 Member(s) | 10032 Guest(s)
