38-690 audio problem
Chuck, when at a loss, if you have the specifications for the interstage transformer and you can't find a used good one, you can always have one rewound. I had the problem on a Midwest receiver with a bad power xformer and sent it out with specs and a new looking one came back that fit my end bells perfect. The midwest had a nice pattern stamped on the end bell. They had a perfect match for the core and rewound on it a new one. If they don't, they can rewind on your old one. This radio is just too nice to not have everything right. As I recall, for a large power transformer it was around $100. Yours probably has less wire. I went to a company called "Boeur" I know I misspelled it but some one else can possibly give you a link. As I recall they are in the North West. I was very happy with their service and speed. Not attached in any way with them, just a happy customer. Too nice a radio to not have all of it looking and working right.
Jerry
38-690 audio problem - by chucka - 08-05-2012, 12:57 PM
RE: 38-690 audio problem - by morzh - 08-05-2012, 02:22 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-05-2012, 04:15 PM
RE: 38-690 audio problem - by chucka - 08-06-2012, 12:44 AM
RE: 38-690 audio problem - by codefox1 - 08-06-2012, 11:02 AM
RE: 38-690 audio problem - by Ron Ramirez - 08-06-2012, 03:51 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-08-2012, 08:08 PM
RE: 38-690 audio problem - by chucka - 08-25-2012, 05:25 PM
RE: 38-690 audio problem - by chucka - 09-08-2012, 09:45 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-08-2012, 11:09 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-09-2012, 09:46 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-09-2012, 01:34 PM
RE: 38-690 audio problem - by chucka - 09-10-2012, 10:17 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 10:57 PM
RE: 38-690 audio problem - by chucka - 09-13-2012, 11:25 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 11:41 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-14-2012, 05:47 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 07:46 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 02:46 PM
RE: 38-690 audio problem - by Diverted - 03-17-2015, 11:32 AM
There are currently 6218 online users. [Complete List]
» 1 Member(s) | 6217 Guest(s)
