Trimmer adjuster
Morzh, I made mine and showed details in the first forum on Philco radio discussions. The last page I believe of my thread on my 111 rebuild. Seems to work.
Jerry
Trimmer adjuster - by morzh - 09-09-2012, 03:58 PM
RE: Trimmer adjuster - by jerryhawthorne - 09-09-2012, 10:22 PM
RE: Trimmer adjuster - by TA Forbes - 09-09-2012, 11:39 PM
RE: Trimmer adjuster - by morzh - 09-10-2012, 07:55 PM
RE: Trimmer adjuster - by jerryhawthorne - 09-10-2012, 08:03 PM
RE: Trimmer adjuster - by morzh - 09-10-2012, 09:08 PM
RE: Trimmer adjuster - by jerryhawthorne - 09-10-2012, 11:27 PM
RE: Trimmer adjuster - by TA Forbes - 09-11-2012, 12:03 AM
The speaker table error?
Philco 70 antenna lead
