I need your help guys
The three screws are under the tuning knob. Remove the knob and you will see them.
Here is the link for some tabs that might work.
http://www.philcoradio.com/tech/calltabs.htm
I need your help guys - by PhilcoJohn - 09-09-2012, 03:38 PM
RE: I need your help guys - by TA Forbes - 09-09-2012, 11:31 PM
Philco 91 Tuning Condenser
There are currently 5385 online users. [Complete List]
» 1 Member(s) | 5384 Guest(s)
