Trimmer adjuster
While I was waiting for answers, I simply took a 'large plastic wall anchor, heated it with a Milwaukee gun and stuck the appropriate size nut inside, and let it cool off. Then I used it as the socket.
Long term, I think I will trake a piece of plastick stick, will heat the same nut, and jam it in the end of it, and then will use that. May be drill a hole across and insert a metak rod to make it easier to rotate.
What I found, I was able top use my metal socket, but then I had to rotater and retract to see the real effect.
The rotate - retract was only needed at the high end of scale adjustment and IF adjustmentl at the low end of scale the effect did not change whether I kept the socket in or removed it.
It is doable, just not convenient.
Trimmer adjuster - by morzh - 09-09-2012, 03:58 PM
RE: Trimmer adjuster - by jerryhawthorne - 09-09-2012, 10:22 PM
RE: Trimmer adjuster - by TA Forbes - 09-09-2012, 11:39 PM
RE: Trimmer adjuster - by morzh - 09-10-2012, 07:55 PM
RE: Trimmer adjuster - by jerryhawthorne - 09-10-2012, 08:03 PM
RE: Trimmer adjuster - by morzh - 09-10-2012, 09:08 PM
RE: Trimmer adjuster - by jerryhawthorne - 09-10-2012, 11:27 PM
RE: Trimmer adjuster - by TA Forbes - 09-11-2012, 12:03 AM
The speaker table error?
Philco 70 antenna lead
