Philco Model 18X
I need an on/off volume switch for my model 18X. The parts list I got from Nostalgia Air shows it as Philco part number 33-5024. Can anyone tell me anything about this switch? I have a 500K audio taper with switch that I bought for another radio project. Will that work? The schematic look like it shows a value of 75,000 ohms. Is there some resource out there that will convert old Philco part numbers to current items? Thanks for any help.
Philco Model 18X - by Groundhog74 - 09-11-2012, 06:41 AM
RE: Philco Model 18X - by Groundhog74 - 09-11-2012, 09:28 AM
Philco 91 Tuning Condenser
