Got an Airline 62-303 Movie Dial Radio Today!
You gotta love the well done brown paint on the chassis and IF cans....
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
There are currently 4842 online users. [Complete List]
» 3 Member(s) | 4839 Guest(s)
