Short wire on tuning capacitor on 41-250 and 41-280
Think these are so called gimmick capacitors you are describing. They only connect at one end and are only a few picofarads of capacitance. Zenith did this on some of their radios. A small amount of the oscillator signal is coupled back to the RF input lead of the mixer stage. It was negative feedback that was important at shortwave frequencies.
Richard
[No subject] - by rghines1 - 06-04-2007, 05:59 PM
[No subject] - by Ron Ramirez - 06-04-2007, 06:11 PM
[No subject] - by Raleigh - 06-05-2007, 03:31 PM
[No subject] - by Ron Ramirez - 06-05-2007, 05:57 PM
There are currently 8930 online users. [Complete List]
» 1 Member(s) | 8929 Guest(s)
