38-690 audio problem
Thanks for the link to that thread, it was interesting.
I'll contact the owner of the set and see if he wants to make that investment in the set.
Chuck
38-690 audio problem - by chucka - 08-05-2012, 12:57 PM
RE: 38-690 audio problem - by morzh - 08-05-2012, 02:22 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-05-2012, 04:15 PM
RE: 38-690 audio problem - by chucka - 08-06-2012, 12:44 AM
RE: 38-690 audio problem - by codefox1 - 08-06-2012, 11:02 AM
RE: 38-690 audio problem - by Ron Ramirez - 08-06-2012, 03:51 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-08-2012, 08:08 PM
RE: 38-690 audio problem - by chucka - 08-25-2012, 05:25 PM
RE: 38-690 audio problem - by chucka - 09-08-2012, 09:45 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-08-2012, 11:09 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-09-2012, 09:46 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-09-2012, 01:34 PM
RE: 38-690 audio problem - by chucka - 09-10-2012, 10:17 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 10:57 PM
RE: 38-690 audio problem - by chucka - 09-13-2012, 11:25 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 11:41 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-14-2012, 05:47 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 07:46 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 02:46 PM
RE: 38-690 audio problem - by Diverted - 03-17-2015, 11:32 AM
