another antique radio newbie
Hello everyone,
I have a Philco 46-1201 Bing Crosby special, and I was wondering how to remove the back, to clean the inside without damaging the radio-(it is very dusty & dirty). I just cannot figure it out. The radio works perfect, but the phonograph does not. The radio cabinet is in very, very good condition. Any helpful ideas would be greatly appreciated.
Thank You
diyahnih Icon_sad
another antique radio newbie - by diyahnih - 06-11-2007, 02:41 PM
[No subject] - by Ron Ramirez - 06-11-2007, 06:50 PM
[No subject] - by diyahnih - 06-11-2007, 07:43 PM
[No subject] - by Bill Hutchinson - 06-12-2007, 05:01 PM
There are currently 9972 online users. [Complete List]
» 2 Member(s) | 9970 Guest(s)
