Trouble getting started
I have read that Philco promoted the sales of that set by offering you an autographed Bing Crosby photo! It is a neat little cabinet that was used for other model years as well. Good luck.
Trouble getting started - by Eric Adams - 09-17-2012, 03:57 PM
RE: Trouble getting started - by Arran - 09-17-2012, 05:43 PM
RE: Trouble getting started - by Eric Adams - 09-17-2012, 06:07 PM
RE: Trouble getting started - by jerryhawthorne - 09-17-2012, 08:38 PM
RE: Trouble getting started - by Paul Philco322 - 09-17-2012, 08:52 PM
RE: Trouble getting started - by Eric Adams - 09-17-2012, 09:09 PM
RE: Trouble getting started - by Arran - 09-17-2012, 09:48 PM
RE: Trouble getting started - by jerryhawthorne - 09-30-2012, 12:48 AM
RE: Trouble getting started - by Eric Adams - 09-30-2012, 01:05 AM
RE: Trouble getting started - by jerryhawthorne - 09-30-2012, 03:00 AM
RE: Trouble getting started - by Eric Adams - 09-30-2012, 12:35 PM
RE: Trouble getting started - by Arran - 09-30-2012, 07:56 PM
RE: Trouble getting started - by Eric Adams - 09-30-2012, 11:00 PM
RE: Trouble getting started - by Arran - 09-30-2012, 11:57 PM
RE: Trouble getting started - by Eric Adams - 10-01-2012, 12:23 AM
RE: Trouble getting started - by Eric Adams - 10-01-2012, 07:41 PM
Philco 91 Tuning Condenser
