New Philco 95 Deluxe to share
Hello, Jon: the model 76 and 95 both use PP45 tubes for output, so the speaker should work. Additionally, the speaker jack is the same.
My model 95 chassis is, in my opinion, close to being in the same cosmetic shape as your 76. It is dirtier, but minimal corrosion, just dust/dirt.
Let me know.....
New Philco 95 Deluxe to share - by Philco281989 - 09-21-2012, 06:24 PM
RE: New Philco 95 Deluxe to share - by 7estatdef - 09-21-2012, 06:49 PM
RE: New Philco 95 Deluxe to share - by TA Forbes - 09-22-2012, 11:04 AM
RE: New Philco 95 Deluxe to share - by TA Forbes - 09-22-2012, 11:30 PM
RE: New Philco 95 Deluxe to share - by Ed Locker - 09-23-2012, 09:10 AM
RE: New Philco 95 Deluxe to share - by TA Forbes - 09-23-2012, 02:06 PM
RE: New Philco 95 Deluxe to share - by 7estatdef - 09-23-2012, 02:45 PM
RE: New Philco 95 Deluxe to share - by TA Forbes - 09-24-2012, 09:57 PM
RE: New Philco 95 Deluxe to share - by TA Forbes - 09-24-2012, 11:05 PM
Philco 91 Tuning Condenser
There are currently 5823 online users. [Complete List]
» 3 Member(s) | 5820 Guest(s)
