Picked up this Philco 46-1203 at the Kutztown auction yesterday. I'm curious as to the relatively small platter. Is that normal?
[Image: http://i863.photobucket.com/albums/ab191...e69823.jpg]
[Image: http://i863.photobucket.com/albums/ab191...8548f1.jpg]
Larry
46-1203 - by rocketeer - 09-23-2012, 09:39 AM
RE: 46-1203 - by DeckApe - 09-23-2012, 12:23 PM
RE: 46-1203 - by NostalgiaRadioTime - 09-23-2012, 12:41 PM
RE: 46-1203 - by NostalgiaRadioTime - 09-23-2012, 12:50 PM
RE: 46-1203 - by rocketeer - 09-23-2012, 05:51 PM
RE: 46-1203 - by Jayce - 09-23-2012, 09:24 PM
Philco 91 Tuning Condenser
There are currently 4206 online users. [Complete List]
» 1 Member(s) | 4205 Guest(s)
