48-1263 fibreboard backing
Where can I find reproduction backing for my Philco console? Can I find it custom size or will it be cut to fit? It seems like it would be a tough thing to ship.
I've seen where it would cover the phono/speaker area and have a ribbed area that tucks in at the top. The radio is left exposed, I assume to ventilate the heat generated.
Alan
48-1263 fibreboard backing - by lasurveyor - 09-23-2012, 12:00 PM
RE: 48-1263 fibreboard backing - by codefox1 - 09-23-2012, 02:21 PM
RE: 48-1263 fibreboard backing - by lasurveyor - 09-23-2012, 11:33 PM
RE: 48-1263 fibreboard backing - by Marsupial - 09-24-2012, 07:34 AM
RE: 48-1263 fibreboard backing - by codefox1 - 09-24-2012, 05:49 PM
RE: 48-1263 fibreboard backing - by Steve Davis - 09-24-2012, 06:33 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1518 online users. [Complete List]
» 2 Member(s) | 1516 Guest(s)
