it matches mine, for what that's worth. Looks to be in slightly better shape than mine, too.
Is there a groove around the edge of the top of the lid on yours? It looks to be light in color... mine's dark, but it might also just be filled with dust etc.
46-1203 - by rocketeer - 09-23-2012, 09:39 AM
RE: 46-1203 - by DeckApe - 09-23-2012, 12:23 PM
RE: 46-1203 - by NostalgiaRadioTime - 09-23-2012, 12:41 PM
RE: 46-1203 - by NostalgiaRadioTime - 09-23-2012, 12:50 PM
RE: 46-1203 - by rocketeer - 09-23-2012, 05:51 PM
RE: 46-1203 - by Jayce - 09-23-2012, 09:24 PM
Philco 91 Tuning Condenser
