Turntable reflocking
The phonograph on my 47-1230 was in bad shape. At least on top. The base was rusted and half of the flocking was missing from the turntable. So, I took it upon myself to become a "flocker" :-) I found the attached bottle of brown flocking online (eBay), but I suspect any craft store should be able to get it (like Hobby Lobby). The jar is very small, about the size of a prescription bottle, but it should be just enough for the small turntables used on the 1946-48 automatic record changers. For a larger turntable, I would recommed getting 2 bottles. Any spray adhesive will work for the flocking. I used 3M Super 77 (as we use this where I work so I "borrowed" a can :-) )
Here's how the finished phonograph looks after repainting and reflocking:
Turntable reflocking - by NostalgiaRadioTime - 09-23-2012, 01:41 PM
RE: Turntable reflocking - by Sean - 09-24-2012, 08:44 AM
RE: Turntable reflocking - by NostalgiaRadioTime - 09-24-2012, 05:21 PM
RE: Turntable reflocking - by Marsupial - 09-24-2012, 06:28 PM
RE: Turntable reflocking - by NostalgiaRadioTime - 09-24-2012, 07:38 PM
RE: Turntable reflocking - by Arran - 09-24-2012, 08:39 PM
RE: Turntable reflocking - by 7estatdef - 10-17-2012, 08:48 AM
RE: Turntable reflocking - by jerryhawthorne - 11-10-2012, 07:00 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1679 online users. [Complete List]
» 1 Member(s) | 1678 Guest(s)
