A good "touch-up" stain
I used this stain on my 47-1230. It matched perfectly. Used it to restain the base, where the wood was rotted and the stain was all gone (it must've sat in some water for a while). I then took some of this stain on a cloth and wiped it over the entire cabinet. It did a GREAT job of staining the age cracks / scratches / chips!
A good "touch-up" stain - by NostalgiaRadioTime - 09-23-2012, 01:52 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1535 online users. [Complete List]
» 3 Member(s) | 1532 Guest(s)
