48-1263 fibreboard backing
Look for screw holes if you don't have an actual shot of a stock set. A lot of sets did not have any back covers in that era, although I am willing to be stood corected by the experts.
In any case you can certainly get a sheet of masonite and roll you own. All it would take is measuring an cutting carefully with a saw, and large vents for the tubes. If there was not originally a back, best leave alone. If situated a couple of inches away from a wall there is little potential for hazards. And whatever I wouldn't want to be any closer than that.
48-1263 fibreboard backing - by lasurveyor - 09-23-2012, 12:00 PM
RE: 48-1263 fibreboard backing - by codefox1 - 09-23-2012, 02:21 PM
RE: 48-1263 fibreboard backing - by lasurveyor - 09-23-2012, 11:33 PM
RE: 48-1263 fibreboard backing - by Marsupial - 09-24-2012, 07:34 AM
RE: 48-1263 fibreboard backing - by codefox1 - 09-24-2012, 05:49 PM
RE: 48-1263 fibreboard backing - by Steve Davis - 09-24-2012, 06:33 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2526 online users. [Complete List]
» 4 Member(s) | 2522 Guest(s)
AvatarAvatarAvatarAvatar
