model 76 or 77
Hi guy's,
Anyone know of a good way to distinguish the difference between a model 76 and a model 77 chassis?
Thanks
model 76 or 77 - by murf - 09-23-2012, 02:38 PM
RE: model 76 or 77 - by Ron Ramirez - 09-23-2012, 03:54 PM
RE: model 76 or 77 - by murf - 09-23-2012, 04:02 PM
RE: model 76 or 77 - by Ron Ramirez - 09-23-2012, 07:22 PM
Philco 91 Tuning Condenser
There are currently 5610 online users. [Complete List]
» 1 Member(s) | 5609 Guest(s)
