Quote:Is there a groove around the edge of the top of the lid on yours?
Yes, there's a groove seperating the lighter colored large square from the darker surrounding area of the lid.
Larry
46-1203 - by rocketeer - 09-23-2012, 09:39 AM
RE: 46-1203 - by DeckApe - 09-23-2012, 12:23 PM
RE: 46-1203 - by NostalgiaRadioTime - 09-23-2012, 12:41 PM
RE: 46-1203 - by NostalgiaRadioTime - 09-23-2012, 12:50 PM
RE: 46-1203 - by rocketeer - 09-23-2012, 05:51 PM
RE: 46-1203 - by Jayce - 09-23-2012, 09:24 PM
Philco 91 Tuning Condenser
